mh 44
dbehr
02-03-2006 11:00:44
i have a 44 that has a lot of play going into the steering box. any suggestions to fix or a salvage yard near e central il? thanks
Harris Guy
02-03-2006 15:06:24
 Re: mh 44 in reply to dbehr, 02-03-2006 11:00:44
Odds are that a salvage yard is a long shot to
correct your steering play, since it is common
for 44's to have worn or missing bearings on the
worm shaft. After two decades, the seal beneath the steering assembly starts to leak, by five
decades, the lack of gear oil has ruined the bearings, or more. Even with cages, cones, the
box bousing and worm shaft, in hand, a good supply
house for seals/bearings, will match your needs.
Having a MH parts list manual will help, since
diagrams show what should be there. The two bearings on the worm have different numbers, they
do not match. You need one Timken 5-BA,one Timken 5-BC. By testing, one fits better on the worm end
than the other. The old MH numbers only guide, as
most are obsolete. Good Luck.
