6 cylinder into 44-4
Scottct
02-02-2006 15:45:44
Will a 226 continental fit into a 44-4 chassis? I have a 4 cyl tractor with a bad motor and a good 6 cyl continental 226 which is the correct engine for a 44-6. What changes will I need to make? thanks in advance for all input
770 puller
02-05-2006 14:55:12
 Re: 6 cylinder into 44-4 in reply to Scottct, 02-02-2006 15:45:44
Yes, It will fit in with a little work!
jd2830
02-03-2006 04:00:27
IT HAS TO BE A ROWCROP CHASSY NOT A STANDARD FOR THE 6 CYL TO FIT
jd2830
02-03-2006 03:59:13
THE FRAMES ARE THE SAME. THE HOOD OR GRILLES ARE DIFFERENT ALSO THROTTLE LINKAGE.
Sam in Mo
02-02-2006 17:42:17
no the frame is longer the fuel tank all the sterring and fuel linkage and probably some other things that i forgot
