mf65
jerryg904
02-02-2006 06:00:26
Ive recently bought a mf65, it has little or no brakes, the weep hole leaks a little and the clutch isnt good,ive read that the clutch is supposed to disingage half way down and the pto all the way down, any thoughts to what i need to do to fix these problems
Ed TN
02-04-2006 16:24:20
 Re: mf65 in reply to jerryg904, 02-02-2006 06:00:26
Hi, jerryg904. You sound just like a guy a work with.
Let me know when you get your parts.
Ed
Eric in IL
02-02-2006 14:07:19
I am replacing the brakes on my 65 now. Went to the dealer today to order parts. It is going to cost me around 120 bucks for four friction disks, six return springs, and two oil seals. I thought that was pretty cheap considering I got 35 years use out of the last brake job. The brakes seem pretty easy to replace if you have a floor jack and a cherry picker. I had leaking seals on the differential carrier. They were not leaking bad, but enough to grease the pads.
You are correct about how the clutch should work. If my memory serves you set clutch linkage as follows: Put a 1 inch spacer between the clutch pedal and the foot board. Your P.T.O. shaft should just stop turning when the clutch pedal touches the spacer. Just adjust the length of the linkage until this happens.
As far as the oil leak, it can only be coming from two places- engine rear main seal, or transmission input shaft. If it is not leaking real bad or causing clutch slip problems I wouldn't worry about it. If it is causing clutch problems you will most likely have to split the tractor at the clutch and replace clutch and seals.
