30b and 34a loader part number help
Mattm
01-31-2006 05:24:10
I am looking for the following part numbers so that i can order them online. i haven't decided what manuals to get yet. 1977 30b with 34a loader a3-152 perkins diesel.
part numbers needed -
air filter - large outer, also is there supposed to be more than the round plate over the outside of the filter?
dipstick - on some sites it shows two for 30b with 152 ?
large filter for loader - appears to be leaking from it thought i might replace to get rid of leak.
any info is greatly appreciated
Matt
Big Dean
01-31-2006 10:20:38
 Re: 30b and 34a loader part number help in reply to Mattm, 01-31-2006 05:24:10
The outer air cleaner element part number is 1094 056M91 the inter element is a 1094 269 M91 I don't have a parts book for the loader filter.
Jack in NB
02-01-2006 03:37:00
 Re: 30b and 34a loader part number help in reply to Big Dean, 01-31-2006 10:20:38
My 34 (not 34a) has a 1039 161 M91 cartridge in a can about 5 1/4" od x 8" high.
Fram C1672 or Gresen K23012 cartridges fit. The Fram is listed as a 25 micron element, and the Gresen at 33 micron.
Fram C1671 also fits mechanically, and is listed as a 10 micron.
We use the Gresen 25 micron.
Dean - do you have any comment on the selection of the various screening sizes - 10 - 25 - 33 micron?
Jack
Mattm
02-01-2006 08:20:16
 Re: 30b and 34a loader part number help in reply to Jack in NB, 02-01-2006 03:37:00
thanks for the info everybody. I went ahead and ordered some manuals so hopefully will be able to find what i need in them going forward. Anybody have feedback on the dipstick... i see two seperate part numbers that reference the 30b and the ad3-152.
Jack in NB
02-03-2006 04:06:01
 Re: 30b and 34a loader part number help in reply to Mattm, 02-01-2006 08:20:16
Hi Matt -
My parts books for all my 152's and 203's (30, 35, 40, 135 UK, 135UK, 165) show dipstick part number 731 117 M91, Perkins 31786912.
The 30A is a bit later, (it has the 3 cyl 152, while the straight 30 has the 4 cyl 203) and might be different - are there any of the above models in your vicinity?
If so, you can check:
- if the tube holding the stick is the same at the top - just a straight piece of pipe, and
- if the tube length above the pan/block seam is the same as yours.
If so, it's a pretty safe bet it's the same.
Good luck!
jack
