Massey Harris 22 Clutch and brakes
John Studinski
01-30-2006 21:50:37
My Massey Harris 22 is getting near the end of its clutch and brake lifespan and will need some attention in these areas soon. It seems as though seals are leaking around the rear engine seal, the pto gearbox seal, and both rear axle seals. While I have it apart, I would like to change these out. My question is two-fold. First, I am striking out at NAPA, Carquest, Bumper-to-bumper, etc. with any clutch or brake parts. Do you usually replace these or have them relined and if relined, by whom?
The second part of my question deals with the sizes of these seals. What am I looking at for axle seals, rear engine seal, and pto seal for sizes?
Any help or advice is appreciated.
Tom Dold
02-01-2006 09:18:37
 Re: Massey Harris 22 Clutch and brakes in reply to John Studinski, 01-30-2006 21:50:37
John
I have a NOS clutch disk for your 22.
I also have one set of linnings for the brake disks (4 linnings enough for 1 side). If interested contact me.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
Tim in NB
01-31-2006 16:24:31
For your rear main seal, I would buy a bottom end gasket set since you need to remove the oil pan anyway. The Victor Reinz number is OS20509 providing you have the original engine (140 cu. continental). For the other seals, if you can get the number off of them, any bearing shop can cross them. If you have a parts book, you can use the numbers from it.
