MH30 Bendix Drive question
Rod in Smiths F
01-30-2006 19:33:23
Last fall I had a starter guy replace the Bendix spring on my MH30's starter. He said if I used a 12V system I would be back for lots more of them, because the spring was not designed for the impact of a 12v starter. He was right, apparently.
It's missing its cog on the flywheel more and more these days, whining out of control when I hit the starter button. Repeated tries on the starter switch don't work, but if I flip the engine over with the crank and try the switch again, it catches and starts the engine normally.
Why is that? The problem happens too often to be a missing cog on the flywheel.
Thanks,
Rod
504
01-30-2006 20:26:56
 Re: MH30 Bendix Drive question in reply to Rod in Smiths Falls, ON, , 01-30-2006 19:33:23
Rod if you put a mark on the crank pulley you will find that it stops in the same place most of the time. But I would check the spring and make sure that the starter and flywheel teeth are fully engaged(the starter Bendex can be shimmed)
01-31-2006 05:00:57
 Re: MH30 Bendix Drive question in reply to 504, 01-30-2006 20:26:56
Thanks for the advice. I'll take it off one of these days and get the starter guy to go over it.
If the Bendix won't engage at the time I take the starter off, that portion of the flywheel would have to be at fault if it were a missing tooth, right? Last time I did it the flywheel cogs in that section were fine.
I'll ask him about shimming the Bendix for a better fit with the flywheel.
I've also thought about having him rewire the starter for 12V. When starting on 12 it hits with a brutal impact and turns very fast. It has to be hard on itself. On my Chrysler M47 marine engine I have a similar 12V alternator/6 volt starter combination but it doesn't seem hard on itself at all. I've used it that way for twenty years now without a problem. The starter guy told me that some 6 volt starters had Bendix drives which are well protected from impact and others such as the 30's which are exposed.
