MF 165 Throttle Linkage
RSpurling
01-30-2006 12:37:30
I finally had a full day this past weekend to start servicing my now 2 week old tractor. The throttle lever is creeping on me causing the RPM"s to rise. I can pull the lever up through the hole and the creep stops, but I have limited movement.
Looking underneath at the linkage when I pull the lever up, I can see the spline sliding up and down. I tried to tighten/adjust everything, but it appears that something has worn beyond adjustment. Before I go off throwing money at an entirely new linkage assembly, anyone have any suggestions on what to try next ot replace?
David Gates
02-03-2006 17:12:51
 Re: MF 165 Throttle Linkage in reply to RSpurling, 01-30-2006 12:37:30
I had the same problem. It is quite common on these tractors. I just spot welded the rod in the
disc. It gave me better control than the tractor
had when it was new.
lonestarjeff
02-02-2006 17:38:08
I have the same problem w/ mine. Thought it was the friction disk, bought new one & installed it w/ no effect. Kept tightening the pinch bolts until I sheered one. That's when I discovered the spline at the tip of the shaft slipping out of the throttle lever.
It's not too much a problem w/ mine since it will hold around 1400rpm, but you've got me thinking about it again.
Jeff
DavidP, South Wales
01-31-2006 00:17:32
Hi,
Not sure about the item you refer to as the spline. Starting at the top, you have the throttle handle then the grommet then the friction disc and dished spring washers. Under these is a nut to tighten and increase the friction on the handle. IF the nut is fully tightened with no improvement then the disc needs to be replaced and probably the dished washers as well. Part numbers are below.
880 714 M1 Disc 1
880 713 M1 Washer 1
880 712 M1 Washer 3
377 119 X1 Grommet 1
Regards
DavidP
