Mass 202 power steering?
greg m
06-11-2000 16:19:16
Looking at a massy 202 with loader. How easy should it be to turn the steering with tractor running? Like any other tractor with power steering, easy? This one i could hardly tell it had ps.
If i need to fix, are parts expensive and hard to find?
Is this tractor the same as a 35?
can anyone send specs on this tractor like HP forward and reverse speeds.
thanks greg
michael dipierro
02-08-2005 19:25:54
 Re: mass 202 power steering? in reply to greg m, 06-11-2000 16:19:16
Hi i own a 202 mf,awhile back we had the same problem.So what i did was i jacked up the front of the machine and drove both king pins out. The one side was very hard to remove. When i finally removed them i took emery cloth and cleaned up very good. Also replace your grease fittings. One other thing replace your powersteering filter. good luck. I am having a problem trying to find out where to pipe up my cab heater.I own a massey furguson mf 50 industrial backhoe an loader the machine has a 4 cylinder perkins diesel engine.
