Alternator problems - MF 40
Greg Reed
01-29-2006 11:55:18
I've got a problem with the alternator / charging circuit on my MF 40 Ind. With the engine running, there's about 18V at the battery, and the ammeter is showing a positive charge of 30+ Amps. After a few minutes, the alternator gets very hot to touch.
The Delco Remy 12V alternator looks original, but the external voltage regulator is only a year old.
Any tips for how to diagnose which component is at fault?
Greg_KY
01-29-2006 12:26:11
 Re: Alternator problems - MF 40 in reply to Greg Reed, 01-29-2006 11:55:18
Voltage regulator.
Bob
01-29-2006 13:59:31
 Re: Alternator problems - MF 40 in reply to Greg_KY, 01-29-2006 12:26:11
To add to that, the voltage regulator must be well grounded. If it is mounted with rubber grommets for vibration resistance, there will be a ground braid to connect the ground past the grommets. If this is broken, or missing, this system can overcharge.
I don't know how the circuit is hooked up, in some cases a broken voltage sense wire to the regulator will cause overcharging.
Likely, it IS a bad regulator, I just suggest you check the items above before laying out $$$ for a new regulator.
