massey 35x
glennn
01-27-2006 04:13:06
my massey 35x drives on when clutch is engaged and does not want to go into gear, I would of believed this to be a clutch adjustment issue. only it happened suddenly not over a period of time is there a easy way of checking clutch, or would it be a gearbox problem?
frank glass
01-27-2006 14:10:42
 Re: massey 35x in reply to glennn, 01-27-2006 04:13:06
the fingers on the clutch assemble have probably
broken, remove the inspection cover located directly under the bell houseing and look at the fingers (all 3). These 3 fingers are depressed by the throw-out bearing when the clutch is pressed down.
Big Dean
01-27-2006 10:57:36
Remove the inspection plate from the transmission bellhousing and look for parts laying in that area it sounds like you either have a broke release finger pin or one has came out that is not uncommon on those clutch.
glennn
02-04-2006 23:11:25
 Re: massey 35x in reply to Big Dean, 01-27-2006 10:57:36
does anyone have a diagram of a clutch assembly for a 35x,The problem i have is upon removing inspection plate the clutch assembly looks bent on the shaft and i am trying to determine what has broken any help would be appreciated.
Thomas
01-27-2006 05:01:19
Does it dissengage suddenly? If so it could be an oil seal allowing oil to contaminate the plates. Check for oil leaking from the drain hole.
Larry in Pa.
01-27-2006 04:52:10
You could have a broken clutch finger,this happened on our Ferguson 40, with the same symptoms.
