135 wheel studs
SuperAliMac
01-26-2006 05:50:11
I need to replace three wheel studs on the back of my 135. Is this possible by just removing the drums or does the hub have to be removed. If so can anyone tell me where to start with that
Cheers SuperAliMac
SuperAliMac
01-30-2006 02:02:13
 Re: 135 wheel studs in reply to SuperAliMac, 01-26-2006 05:50:11
Thanks will try that.
Dean
01-26-2006 06:17:33
I was able to replace 2 on my MF-35 without removing the hubs. It is necessary to grind the head of the new stud some in order to get it started into the axle flange. Once that is done you can pull it into position with a good lug nut. Add some grease to the stud and the back side of the nut.
Dean
