Hydraulics on MF35
Darryl
06-09-2000 16:51:53
I have a mf35 diesel with a loopy hydraulics system.. the fluid is where it should be.. but the hydraulics are all over teh map as it goes through it's range... they will bounce the tractor with a load on them.. drop down suddenly.. then rise right back up and freeze in the high position...
what can I do?
rod
06-13-2000 04:36:13
 Re: Hydraulics on MF35 in reply to Darryl, 06-09-2000 16:51:53
this sounds as though the relief valve is sticking or maybe a filter is dirty get a manual and see if you can make any adjustments first. regards
rod
