MH 33 questions
jdjack
01-24-2006 19:16:10
I got bought my first MH tractor. It's a 33 (i think). It has a 3pt hitch and a wide front.
Are they live hyd and pto?
The front end has alot of slop, when going down road at higher speeds. Are parts avaible for these tractors? The brakes don't work very good, are they hard to replace?
Can repair manuals still be purchased?
Thnaks for any help, will be needing alot more.
Bob N.Y.
01-25-2006 07:07:07
 Re: MH 33 questions in reply to jdjack, 01-24-2006 19:16:10
The hydraulic pump is driven directly from the engine timing gears, therefore it has live hydraulics. Live pto was optional equipment. It was accomplished by means of a hand operated differential clutch. If there is a tall lever by the brake pedals, you have live pto.
Logan
01-24-2006 19:59:35
Well, as for the front end, there is an adjust ment on the gear box but most likely the bearings are out, real easy to replace but i dont know where you would find some. My 33 dont have live clutch but some do. breaks are fairly simple to replace and can get parts from car quest for them.
