mf35 starter problems
kevin j
01-24-2006 16:12:35
Starter doesn't turn the engine ,just get a high pitched electrical whirring sound when key is turned.Fed up bump starting her, is it solenoid or starter problem.
kevin j
02-05-2006 02:23:12
 Re: mf35 starter problems in reply to kevin j, 01-24-2006 16:12:35
Thanks for replies.Dodgy connection into solenoid(small wire nearest engine block moves around a bit)Fiddleduntil got good connection and now starts on its own(with a little help from "start you bastard" aerosol)MF35 is 4cyl diesel.Thanks again.
Mark Howell, MI
01-25-2006 14:49:09
When that happen to me I removed starter and engaged the starter off the battery and got it spinning and put it back on tractor. Thats been 2 years and it hasn't seized up again.
Rod in Smiths Falls, ON,
01-25-2006 18:06:03
 Re: mf35 starter problems in reply to Mark Howell, MI, 01-25-2006 14:49:09
Now that you mention it, Mark, on my 30 I have to use the crank occasionally to turn the flywheel a little and then the starter engages again.
01-24-2006 18:12:34
When my MH 30 did that I took the starter to a local rebuild guy and he replaced the Bendix spring for twenty bucks. No problem getting the parts: he had them in a box on his bench.
Dean
01-24-2006 17:33:54
You do not say what engine you have so I do not know the specifics of your starting system. What follows is generic information.
Sounds like the starter drive is not engaging the flywheel. The high pitched whirring sound is probably the starter motor running. If you hear no grinding sound your starter drive is probably siezed. A new drive will probably fix it.
Dean
old
01-24-2006 17:27:34
That could be a weak battery, bad cables/connections or the starter. most of the time if the soliniod goes bad it will just click
