Massey Ferguson Side Mounted Mower
Stockdale Chris
01-22-2006 17:44:09
My friend has two MF side mounted mowers. You cannot read the model number on either nomenclature plate. The serial number one one of them is 238 033899 and the other one is 238 033639. Would anyone out there be able to tell me what model they are? Thanks, Chris
Joe in Ontario
01-24-2006 12:43:34
 Re: Massey Ferguson Side Mounted Mower in reply to Stockdale Chris, 01-22-2006 17:44:09
Stock: If your mower cuts behind the wheels and goes on the 3pt hitch with a wood pitman and two belts, the model is #32. Joe in Ontario
Stockdale Chris
01-23-2006 03:43:24
Thanks marlowe. It is a 3 point that mounts behind the rear wheels and cuts on the side. Appreciate the response.
Mighty Fine
01-23-2006 04:17:15
 Re: Massey Ferguson Side Mounted Mower in reply to Stockdale Chris, 01-23-2006 03:43:24
Do they have pitman arms? Are they belt drive? That would narrow the search a bit.
Stockdale Chris
01-23-2006 14:07:28
 Re: Massey Ferguson Side Mounted Mower in reply to Mighty Fine, 01-23-2006 04:17:15
Thanks for the reply Mighty Fine. They do have a pitman arm that is driven by a drive belt. Appreciate it, Chris
Stockdale Chris
01-23-2006 03:42:48
marlowe
01-22-2006 18:53:15
when you say side mount do you mean they mount between the front and rear wheel or behind the rear wheel?so is it a side mount side or side mount rear
marlowe
01-22-2006 19:04:13
 Re: Massey Ferguson Side Mounted Mower in reply to marlowe, 01-22-2006 18:53:15
i have a MF-31 dyna-balance mid mount on a to-20 that will cut above and below ground level. could not recall no. in first post. your ser no. is no help to me
