Perkins A 3.152 oil pump questions.
William Bos
01-21-2006 13:43:54
Hey,
We are putting a new oil pump on a Perkins 3 cyl diesel and have some questions. Forst, we bought new pick up and supply pipes, along with new olives and nuts. How tight should these be tightened? ( Both on the pump and the block.. ) I assume the olives will expand when tightened, so all will be snug??
Also, the stabilizer bracket the bolts to the main cap was not attached to the pickup tube, so after we get it all straight and marked we are going to braze it on? Do these always come seperate to be assembled on the engine!!
Thanks for the help & take care,
Will
DavidP, South Wales
01-22-2006 09:25:55
 Re: Perkins A 3.152 oil pump questions. in reply to William Bos, 01-21-2006 13:43:54
Hello,
You will probably have the new type pickup pipe with the strainer attached to it. The tightness of the pipe nuts and bracket bolts is down to a sensible level remembering that you are only tightening on a tube. If you have the old type of tube it would be advisable to obtain the latest bracket and clamp and rubber bush. We have had several brackets break over the years from the pipe resulting in low oil pressure and air in the oil.
Regards
DavidP
William Bos
01-22-2006 10:37:46
 Re: Perkins A 3.152 oil pump questions. in reply to DavidP, South Wales, 01-22-2006 09:25:55
Hey David,
Thanks for the rreply. I have the new style with the strainer attached to the tube ( pickup i guess. ) I also have the bracket wirh a nut welded on it. Is there something else that I am missing?
Thanks & take care,
Will
DavidP, South Wales
01-23-2006 10:57:58
 Re: Perkins A 3.152 oil pump questions. in reply to William Bos, 01-22-2006 10:37:46
Hello, yes there some bits missing;
36631118 Clip 1
33817308 Bush (rubber) 1
Both of the above are up to number UA 274432D
Regards
David
Wi9lliam Bos
01-23-2006 13:38:37
 Re: Perkins A 3.152 oil pump questions. in reply to DavidP, South Wales, 01-23-2006 10:57:58
Hi David,
Thanks for the info. Just to confirm I am using the new style pickup with the screen attached ( welded right on ) the pipe. So this should all work then
It is an old style MF35 Perkins 3 cyl diesel block with the rope seal. The only serial nubers on it are CL 1807534C and C 3711289
Thanks & I will get the dealer to order these parts for me!!
Take care,
Will
