fresh start 44
Kevin
01-21-2006 12:40:22
my 44gs is getting a fresh start. Everything in the motor has been replaced. I was wondering what the best way to start it is and if i should do anything speacial for first start up and how i should treat it for how long?
MARLOWE
01-21-2006 13:10:52
 Re: fresh start 44 in reply to Kevin, 01-21-2006 12:40:22
forgot to say if your valve train is not set do that at first start up and recheck after the first hr.
marlowe
01-21-2006 13:08:33
i have rebuilt 75 to 100 engines . get it running and set the timeing and check for leaks and make sure all fluids are full water, oil ,gas and then go and work it for at least 1 hr.at operating temp do not lug it for long periods of time. to set rings WATCH all the gauges, look , listen, and smell. change oil and filter after 3 to 5 hr.DO NOT BABY IT
Kevin
01-23-2006 14:48:06
 Re: fresh start 44 in reply to marlowe, 01-21-2006 13:08:33
Will a good day of plowing be good for its first day of running or am i better just cruising around the roads for a while?
