MF 1100 remotes
Kevin Bismark
01-20-2006 20:57:49
Noticed that the loader wants to sink when I have a heavy load on it now, are there any parts to replace in the remote valves that you can still get or is it a lost cause, haven't looked at the manual yet, will try to do that tomorrow, got the cab painted today and will put a second coat on tomorrow and think about putting it on next Saturday..
barnrat
01-21-2006 04:33:39
 Re: MF 1100 remotes in reply to Kevin Bismark, 01-20-2006 20:57:49
First it depends on if you have an early or late styled valve. On the early styled I don't think you can rebuild them, but you can adjust them for wear. An I&T or service manual can show the adjustment procedure. On the late styled you can only adjust the return to neutral setting. You can rebuild the late model valve with still available O-rings and seal ring, also I think you can also get the internal springs if any are broken as well as some of the other spool parts.
Kevin Bismark
01-21-2006 18:53:21
 Re: MF 1100 remotes in reply to barnrat, 01-21-2006 04:33:39
Thanks, didn"t have time to look at it today but will look in the book and look up the serial number and see what year it is, think that is the only tractor we have that I never looked up the year..
