Power Steering for 444?
Scotty
06-08-2000 21:30:39
Has anyone added power steering to a 444?
jeff
07-19-2000 13:23:36
 Re: Power Steering for 444? in reply to Scotty, 06-08-2000 21:30:39
I might know someone who has a power steering unit. Email me if you are interested.
Jim NW KS
06-14-2000 21:08:33
I Just made a bracket and installed a pickup powersteering unit on the underneath side of the frame of my MH 44 and modified the drag link arm and welded a bracket on the tie rods hooked up the unit to the tractor hydraulics. I have great luck with this. You just have to experiment with brackets and where you want it I had to move the steering shaft off to the right of the tractor to hook it up to the pickup unit. I am going to try and set into a different area to make it look more clean.
Steve NW WI
06-14-2000 01:16:02
Have added an aftermarket char-lynn p/s unit to a 44, got it used, don't even know if they still make 'em, but basically all it was was a unit that was installed in the steering shaft that ran off the tractor hydraulics. Had to use grade 8 bolts instead of roll pins thru the connections between the shaft & pump though to keep them from shearing off.
If you need more info, email me & I will go out and get whatever numbers I can find off the booster, etc.
Steve Anderson
Steve NW WI
