steering column throttle
Greg Chapman
01-19-2006 15:38:55
I working on a massey harris 44 and like to put the throttle on the steering column, i have all the brackets needed, but cant find out how it connects up to the carberator. any pictures would be helpful. thanks
Tom Dold
01-23-2006 13:50:48
 Re: steering column throttle in reply to Greg Chapman, 01-19-2006 15:38:55
Greg
It depends on the serial #. The early 44s used a cable. These used a cast iron mount and a cast iron throttle lever with a spring to hold it in position. After this style the throttle was moved below the steering column. Starting serial #42783 the throttle was moved back to the column and used a friction disc to hold the engine speed.
I will e-mail a picture of the latest one to you.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
greg chapman
01-23-2006 16:16:54
 Re: steering column throttle in reply to Tom Dold, 01-23-2006 13:50:48
thanks for all the help.will find out the serial# tomorrow,
