mf35 timing
phil25
01-17-2006 18:03:29
Would anyone have a few minutes to post the point gap and degrees of timing for a 1964 massey 35, Z134 engine?
Was sure i had this info/book with me "but" i admit i forgot it."the settings and the book :)" thanks
=CityBoy=
01-17-2006 20:20:39
 Re: mf35 timing in reply to phil25, 01-17-2006 18:03:29
Check under Tune-Up Specs under Research & Info on left side of this web page.
Might want to consider checking and adjusting valve clearances to spec. Relatively easy to do and sure improved how my Z134 runs.
phil25
01-18-2006 03:20:39
 Re: mf35 timing in reply to =CityBoy=, 01-17-2006 20:20:39
Thanks, i forgot about the tune-up spec section "also" :), funny thing is if i looked left while typing i should of seen it. Already did the valves, suspected they had been adjusted before, the help call came.
