135 Governor???
JSMILLER
01-16-2006 19:00:51
Bought this 135 engine runs away too many RPM's!!
I pulled it apart and the governor balls flew apart. I replaced the governor with a set from a TO-30 Looked New!! No wear showed on them. Put it back together and it still runs away. I cannot feel any resistance from The governor at all??? anyone have any Ideas???? Thanks in advance.
JM
Big Dean
01-16-2006 20:14:24
 Re: 135 Governor??? in reply to JSMILLER, 01-16-2006 19:00:51
The carburetor to governor arm link being out of adjustment will cause that problem. The link has to be adjusted to the right length before the governor will perform as it should. If it is off just a little that is all it takes. If you need help adjusting it Email me.
