Perkins engine (MF35 ?)
Gerd
06-08-2000 16:35:43
Hi everybody,
you might be able to help with a problem I and two
friends have with a Perkins 3cyl (3.152 ?).
Four years ago we bought an oldtimer fishing
boat (96 yrs) in Germany. It was basically rebuilt
in 1975-1980 and fitted with the Perkins engine.
The only info we got about this engine is that
it is a tractor engine modified to fit the boat.
Since the engine has been built into the boat
there have been serious problems with the starter.
It is a Bosch starter which obviously isn't the
correct one. The info we got was that there is
no original starter available in Germany.
Surfing the web I stumbled over the MF35 and the
Perkins engine. So here are my questions.
How can I find out whether our engine was a MF35
(or other model)
engine (which serial numbers do I have to look
at) ?
If so, which starter would be the correct one ?
(I found some references to Lucas starters,
but also to Delco-Remy )
Any help would be greatly appreciated
Gerd
John Miller, III
06-09-2000 07:53:34
 Re: Perkins engine (MF35 ?) in reply to Gerd, 06-08-2000 16:35:43
Marine applications... use a "Marine" starter. Unless you feel lucky down in the hull for an explosion... (You don't want any "sparks" off the starter armature in a confined space)
Jack in NB
06-09-2000 10:49:58
 Re: Re: Perkins engine (MF35 ?) in reply to John Miller, III, 06-09-2000 07:53:34
Mea Culpa.
Excellent point, John. Hadn't thought of that.
Jack in NB
06-08-2000 17:37:01
Hello, Gerd -
Serial number may be at the top of the block, left side, over the injector pump (early models), or right side on the flat in front of the fuel pump.
If the adaptor plate and flywheel are similar to the farm units, the starter is on the right under the fuel pump, and a whole raft of them fit - 35, 135, 65, 165.....
You might be able to borrow one to try.
Delco numbers that I know for certain (all start with 110):
7503 7512 7540 7853 7860 7870 8649 8662
Rebuilt, $200 - $225 US outright (no exchange).
Hope this helps.
