PLEASE PLEASE HELP (WATER PUMP PROBLEM)
james brooks
06-08-2000 13:24:30
Hello everyone,
I have a 1955 TO-35. The other day i started hearing some noise and of course checked it out.
The fan was wobbling and beating up the fan shroud. I have taken the front cover off of the water pump(which also incorporates the fan pulley, shaft, sealed bearing and impeller. It looks as if the impeller is pressed on. How do i get this whole assembly apart to replace the bearing (which i think is obviously shot)/????? ?? I have a borrowed implement on the back which I desperately need to return. Any help will be MUCH appreciated.
Thanks all,
James Brooks Lincolnton, GA
