MF 35 Stuck Transmission
Jeff L
06-08-2000 09:45:33
I have a 1962 MF-35 diesel, the transmission is stuck in reverse. I cannot move the shifter from this position. Does anyone have any suggestions? Thanks Jeff
CHRIS-MF35
06-08-2000 16:35:40
 Re: MF 35 Stuck Transmission in reply to Jeff L, 06-08-2000 09:45:33
I have never heard anyone else suggest this, however it works on mine. Pull up on the shifter and move it to the location it's stuck in then let it back down. I don't know but it work on mine every time. Let me know if it works for you, might be on to something here.
glenn
06-08-2000 18:04:37
 Re: Re: MF 35 Stuck Transmission in reply to CHRIS-MF35, 06-08-2000 16:35:40
i have a massey 135 that this just happend on last weekend, i had to take the shifter asm off the tractor and reinsert the shifter arm into the shuttle on the rod. its pretty easy to do, just the dissambly was a pain.
glenn
Danny
06-08-2000 14:57:43
Some times you can manipulate the shift rail throught the fill plug opening next to the shift lever. Put the Hi-Lo lever in neutral to relive any pressure on the gears and use a long rod or screwdriver to move the gears.
bob
06-10-2000 09:12:02
 Re: Re: MF 35 Stuck Transmission in reply to Danny, 06-08-2000 14:57:43
This used to happen frequently on a 1958/9 MF 35
four cylinder version I used at the time.its down to worn selectors but can be relieved by inserting log rod or screwdriver through oil filler hole by gearstick
Jeff L
06-09-2000 08:18:23
Thanks gang for all the insite and response.
