frosting propane lines
cleatusj
01-14-2006 12:01:59
Engine runs bad when propane line frost up. What would cause this.
ILL John
01-15-2006 15:54:25
 Re: frosting propane lines in reply to cleatusj, 01-14-2006 12:01:59
Are you starting AND shutting off this tractor on VAPOR? IF you start it on vapor and turn on the liquid before the engine has warmed up somewhat, it'll frost the line, choking off the fuel. I start mine on vapor, run it until the engine temp gauge moves up, then turn on the liquid valve,turn off the vapor valve. Then when done working, turn off the liquid valve, turn on the vapor valve and let it run until I figure it's burned the liquid so I can start it tomorrow on VAPOR. If you have coolant going thru the regulator, this should be the correct procedure. John
JJ. in B.C.
01-14-2006 20:19:32
Liquid Propane in the lines can cause frosting
JJ.
