pto trouble
geovair66
01-13-2006 16:46:03
hey all! ive got a 1964? mf model 50 with ptoproblems. it will engage to the rear end fine and will engage with the engine off to the engine side fine and will work both ways. the problem is it wont engage with the engine running (it grinds trying to engage) and when it is engaged it wont stop with the clutch pedal. the drive clutch seems to be ok. can anyone help advice how to access? ive looked underneath for an access plate and dont see one. and nothing on the sides. does the shifter assy have to be removed for access? any help would be great. thanks in advance frank.
DavidP, South Wales
01-14-2006 09:01:59
 Re: pto trouble in reply to geovair66, 01-13-2006 16:46:03
Hi,
Do you have a dual stage clutch on this tractor. If you do, does the second stage start around halfway down with the pedal? If this is about right it seems like the clutch plate might be stuck to the flywheel.
DavidP
