Alternator/Tachometer
Peter Horrelt
06-06-2000 21:39:38
The tachometer on my MF85 is hooked up to an output on the Generator. Is there a easy way to get a take off for your tack when you replace the generator with an alternator? What is the Relation (ratio) between belt speed and proper tack readings? Hope someones been through this Thanks....Peter
georgeT
06-13-2000 00:21:21
 Re: Alternator/Tachometer in reply to Peter Horrelt, 06-06-2000 21:39:38
the alternator on my 175D has this set up you may be abble to switch try ct qualiety farm now or your M F dealer
Big Dean
06-07-2000 15:53:34
Some of the 100 series Masseys had a alternator with the tack drive. I can't remember which ones for sure but I think the late 135 & 150 with the Continental engine had one.I think case also had them not sure though. You should be able to find one in a bone yard.
Tyler(WA)
06-07-2000 07:59:07
I'll be watching with keen interest since I did the same thing and now have a dead tach. I could replace it with an electronic tach but it wouldn't look anything like the original.
50 GUY
06-09-2000 10:08:13
 Re: Re: Alternator/Tachometer in reply to Tyler(WA), 06-07-2000 07:59:07
Same with my 50 thats been converted over. Let us know what you find out.
