MORE ON THE MYSTERY MODEL MASSEY FERGUSON INDUSTRIAL LOADER TRACTOR
Ken McWilliams
06-06-2000 19:47:40
I'm still needing to find the model number for this tractor so I can order some manuals.
I worked a little more on the M-F industrial tractor this evening.
On the top rear left of the block is stamped:
203UA115480
On the left side of the block and behind the injector pump is cast: "BILCHROME" It is in capital letters and is in an arch.
Also, on the left side of the block is cast into the surface: "L86"
The style of the front has a rectangular heavy cast iron frame surrounding the grille. The grille has an upper part with two headlights in a perforated metal section having the triangular M-F logo with a tractor pulling a plow. The lower part of the grille is flat and is a large rectangular opening.
The clutch housing has cast on the surface: "894-682M1"
The serial number tag just under the steering column has S/N 9AI395I. The S/N tag has the list of U.S.patent numbers and the Canadian numbers appear to have the years in which the last number is 1966.
It has inboard brakes with a master cylinder on the brake pedal and a slave cylinder on each side of the differential going to the brakes. It, also has mechanical left/right brakes pedals going to the same linkage.
The end of each axle housing looks to have a planetary gear reduction.
The style of tractor is the squarish/rectangular shape similar to the ag style tractors except the shroud around the grille is heavy cast iron instead of sheet metal. The part surrounding the grille is such a substantial piece of cast iron, the front of the loader frame bolts to it on each side. The bulkhead bolted to the front of the engine holding the front axle and the front axle itself are massive cast iron pieces.
The older style M-F's had the rounded fronts. This tractor has the flat front with the three triangle M-F logo.
It looks as though I may have to rebuilt the engine. This evening, I took off a hose from the valve cover and a large amount of pressurized air is rushing out of it which indicate lots of blow-by from the pistons.
Any information on the model identity is appreciated.
One person suggested that it is a model 50C. I'm familiar with the Ag style M-F 50's with the rounded front, but my tractor doesn't look anything like them. I thought when M-F went to the squarish fronts, they began using a 3 digit model number.
HELP!
Ken McWilliams
Dayton, OH
Samuel DJ Arboleda
10-13-2000 17:48:36
 Re: MORE ON THE MYSTERY MODEL MASSEY FERGUSON INDUSTRIAL LOADER TRACTOR in reply to Ken McWilliams, 06-06-2000 19:47:40
Hi, Ken...I think your tractor could be an MF 65R Industrial Tractor made in North America. This tractor was equipped with an MF 250 Front Loader and an MF 252 Digger or MF 203 digger and MF 205 Loader....The engine is a 4.203 and could be indirect injection. I suggest to visit a Perkins Engines dealer and using the engine number you can know exactly what MF tractor was fitted with that engine...
Best regards
Samuel
Jack in NB
06-07-2000 06:50:58
From the engine serial number "203UA", the engine is the Perkins AD4-203 model. Probably one of the intermediate series, cast iron liners, may have a rope seal at the rear of the crank. 203UA109488L was the start of the later lip seal engines with lip seals on the rear of the crank.
The same engine is in the later 65's, 165's, 155, 158, 560, 765, Landini R-DT6000 and a whole lot more of the MF 2++ and 3+++ numbers.
Can't help with the rest! Could very well be a 50 series - they were a heavy brute, which fits with the hydraulic actuated brakes.
Darrene Mason
04-02-2002 20:22:39
 Re: Re: MORE ON THE MYSTERY MODEL MASSEY FERGUSON INDUSTRIAL LOADER TRACTOR in reply to Jack in NB, 06-07-2000 06:50:58
hello everyone, I have a old forklift that was made in England. It has on the block cast in, the word "BILCHROME" I need a distributor cap, rotor, and points etc. I have had no luck finding any info. on this engine at all. It is a four cyl. w/ up draft carb. If any one can help me out in any way it would be greatly appreciated.
Please phone me collect at 604-898-4512 or E-mail me. thank-you
