Some basic questions about MF35 3pt hitch hydraulics
Danny Y
06-06-2000 11:17:51
I'm trying to make sure I understand exactly how the 3pt hitch hydraulics work on a MF35. It's my understanding that the PTO does not need to be running, correct? What I'm not sure about is whether the clutch has to be out or not. Will the 3pt hitch operate if the clutch is pushed in? If the clutch has to be let out to raise the lift, will it hold its position if the clutch is pushed in again?
Big Dean
06-06-2000 19:33:40
 Re: Some basic questions about MF35 3pt hitch hydraulics in reply to Danny Y, 06-06-2000 11:17:51
The pto does not have to be engaged for the three point to work on the TO35. if it has a dual clutch when you push the pedal half way down the tractor will stop but the three point & pto if engaged will still operate. When the pedal is pushed all the way down everything stops. If it has a single clutch then the three point will not operate & the pto will stop. with the clutch pushed down. Unless the hydraulics are in really bad shape it should hold up for a little while. If you need more information E-mail me
