165 3 point lift
Isaiah
01-07-2006 12:13:18
I have a MF 165 NOT multi power but a deisle the pto grinds into gear when an implement is on the 3point and it also bounces up and down about and inch . what is up with that
DavidP, South Wales
01-08-2006 09:03:01
 Re: 165 3 point lift in reply to Isaiah, 01-07-2006 12:13:18
Hi,
A grinding clutch may be caused by the PTO adjuster bolts being out. IF you go into the second stage, does the clutch engage freely?
Your bouncing of the linkage might be a serious leak in the system allowing it to drop slightly and then correcting its self. More likely you have a broken piston ring or poppet valve not closing. You can compare this to a four cylinder car engine running on three cylinders.
DavidP
