MF 165 Brakes
Isaiah
01-07-2006 09:50:27
Hey I have a diesel mf 165 with the exhaust on the left as youi sit on it. Not a multi power. It has the round flex axle not the square cast. I had no brakes so i tore it down and found gunk in the housing and on the pads but little ware on the pads. do i have wet or dry breaks and how do i fix them. Thanks
DavidP, South Wales
01-08-2006 09:10:14
 Re: MF 165 Brakes in reply to Isaiah, 01-07-2006 09:50:27
Hello,
You have a Mk1 165 which is probably prior to 1968 fitted with an AD4.203 engine. The ad4.212 was fitted from approx 1968 onwards. By UK history you would definately have a tractor with DRY brakes. Generally they were a pain in the proverbial when they were worn. When you apply the brakes do they grab. It's all or nothing, no gradual application? If so the actuators will be worn and there is only one answer.....the expensive one. You can seperate the two discs and clean out the dust etc from the ramps. IF it works it is generally only short term. If you have good pedal pressure with no grabbing and poor braking efficiency it is possible that the linings will have hardened (assuming no oil present) Having them relined is generally cheaper than new as long as the splines are OK.
Come back if I can help any more.
DavidP
