hyd pressure on a 44
Merv in Sask
01-05-2006 16:49:22
I have a 44 standard I would like to use on our 10" grain auger. but the 1200 lb.pressure it has at hyd. tip is not enough to lift auger.How can I turn up the pressure? Thanks in advance Merv
spitz
01-06-2006 05:04:04
 Re: hyd pressure on a 44 in reply to Merv in Sask, 01-05-2006 16:49:22
On our 44 special we added some washers to the relief valve spring. It is a bolt the sits horizontally by your feet when you sit on the seat if I remember correctly. Our hydraulics would lift anything until we did this to it. Hope this helps.
Harold in Sask
01-08-2006 07:44:11
 Re: hyd pressure on a 44 in reply to spitz, 01-06-2006 05:04:04
I looked up the adjustments in my 44 manual. IT states that you should adjust to 850 min and 1100 max. PSI, so yours is right up there. I think that is all those old girls ever did put out.You need a larger ram. ----Harold
