WHAT MASSEY FERGUSON INDUSTRIAL TRACTOR DO I HAVE?I just bought a Massey Ferguson industrial loader tractor, but cannot find any identification plate on it other than a serial number tag with S/N 9AI395I. It has a 4 cylinder diesel, three speed trans with hi-lo range plus a shuttle shift. No 3 point hitch, but does have a PTO. The cover near the PTO lever says "Engine PTO" & "Ground PTO". I noticed that the PTO will run clockwise and counter-clockwise depending if the shuttle shift is in forward or reverse. The loader is a "wobble" stick with front/back movement lowering/raising the boom & left/right movement tilting the bucket. Everything is massive cast iron. The radiator shell (the grille is missing) and the steering console is all cast iron. Power steering is hydrostatic with no direct mechanical linkage from the steering wheel to the twin cylinders on the tie rod. The fenders are flat topped with almost a diamond tread stamping on top. It appears to be originally yellow and has been repainted yellow. It has M-F logos on the steering wheel and at the top/front of the radiator shell. What model is it and are parts available for it? Ken MCWilliams Dayton, OH
