More on the oil in the clutch housing on MF202
Grapefarmer
01-04-2006 16:16:47
I went to unclog the weep hole, but was not able to find one. I did note a plate on the bottom of the clutch bell housing. Its secured with 4 large bolts. I loosened 2 of the bolts and small bit of water and then thick oil came out. I am going to let it drain all night. So much oil, this just has me baffled.
GaryF
01-06-2006 18:49:12
 Re: More on the oil in the clutch housing on MF202 in reply to Grapefarmer, 01-04-2006 16:16:47
Grapefarmer glad you posted again. If your tractor is gas and shifts forward to reverse via a foot pedal on the right hand side you have a MF204 with instant reverse trans. Transmision could have been swaped. It will have a torque converter in a separate housing from the main transmission. Level is checked via a fill plug on the right hand side down by the pedal. Don't know how oil could come out the starter hole. Can ask a friend who may have encountered a similar problem.
grapefarmer
01-07-2006 15:47:36
 Re: More on the oil in the clutch housing on MF202 in reply to GaryF, 01-06-2006 18:49:12
I checked the ID tag on the dash and its a 202. You may be right, it could have a 204 clutch and trans. I will try and get some pictures tomorrow.
Thanks
-Dave
Grapefarmer
01-07-2006 16:05:05
 Re: More on the oil in the clutch housing on MF202 in reply to grapefarmer, 01-07-2006 15:47:36
I was wrong, it does not have the reverse foot pedal. I was looking a the foot excelerator. My mistake!
I have about 3 quarts of what looks like 5w30 that came out of the clutch area. This trator was bought at an auction and I wonder if someone put oil in the clutch to hide some other problem. It always turned over slow from the day we got it.
GaryF
01-07-2006 17:55:14
 Re: More on the oil in the clutch housing on MF202 in reply to Grapefarmer, 01-07-2006 16:05:05
Dave...that oil will have saturated your clutch discs, sounds like it was in there for some time. I don't know how you could intentionally get oil into that area, although keeping it there would have been easy. That weep hole was there for leak detection and gave a place for the oil to run out.
Aside from the slow turning over how well did the clutch/trans operate?
Grapefarmer
01-08-2006 16:02:23
 Re: More on the oil in the clutch housing on MF202 in reply to GaryF, 01-07-2006 17:55:14
Actually the clutch would grab nice and smooth. I have a old 1950 Case DC that has and oil clutch and it feels the same.
Also the plate on the botton of the bell housting has a gasket, like it was suposed to hold oil in.
Thanks for you input.
-Dave
GaryF
01-09-2006 02:45:21
 Re: More on the oil in the clutch housing on MF202 in reply to Grapefarmer, 01-08-2006 16:02:23
That plate is there so that adjustments can be made to the clutch
Grapefarmer
01-09-2006 14:49:15
 Re: More on the oil in the clutch housing on MF202 in reply to GaryF, 01-09-2006 02:45:21
When I get my starter back from the rebuilder, I'll give you an update on how bad the clutch really is. :)
Gary, thanks for the help.
-Dave
