massey ferguson 135
Harv123
01-03-2006 18:56:35
Can anyone tell me how to find out what year my tractor is? Can you tell from the serial number?Any information would be appreciated. It is from the 1960"s , that is all I know.
Phil Anderson
01-05-2006 06:32:14
 Re: massey ferguson 135 in reply to Harv123, 01-03-2006 18:56:35
The "A" in the later serial numbers refers to the "A" production line at the Detroit tractor factory. They were simply called "A Line" tractors. The larger 1100 series were "B Line" tractors. The 135 up through 285 were A Line. The 1085 through 1155 were B Line. The 1505/1805 built in Des Moines were "C Line".
01-05-2006 08:00:16
 Re: massey ferguson 135 in reply to Phil Anderson, 01-05-2006 06:32:14
It finally makes sense. I never could understand MF's serial numbering system. So, I gotta question for you, my 135's serial number is 9A-20666 obviously it was made in Detroit, but does it mean that they made 20666 tractors (all types) before mine or that they made 20,666 MF 135s?
Christos
Phil Anderson
01-06-2006 07:34:59
 Re: massey ferguson 135 in reply to [email protected], 01-05-2006 08:00:16
It includes all types of A Line Tractors. For example, serial # 9A20666 was made in 1967. They made about 29,835 A line tractors that year including the 135, 150, 165, 175 and 180's. They are all lumped together so you can't tell from the serial number exactly how many of each model were made.
Christos
01-03-2006 19:19:16
Hi - The serial number should be on a data plate on the left hand side of the dash near the starter switch. However, if its missing, there is an easy way to tell - If its gas and it has a four cylinder engine and the castings read Z-134 OR Z-145 then it has a Continental Motors engine. That would mean that its from before 1968. If its gas and has a 3 Cylinder engine it means that its post 1968. If its diesel, then its a perkins engine through out production, but the air filter changed from vertical to horizontal around 1966 on all models so if it has that its either a 1965 or 1966. The MF 135 was made starting in 1965 and ended production in 1975.
If thats not confusing enough starting sometime in 1966 MF changed the way its Serial Numbers were marked from one that looked like a U.S. Social Security number to 9A-XXXXX X.
I think the A means AG too. Not sure, maybe Big Dean would know.
Christos
Harv123
01-04-2006 12:02:48
 Re: massey ferguson 135 in reply to Christos , 01-03-2006 19:19:16
Thanks for the info, I will check it out on my tractor. Was hoping to sell it and am trying to find out the value also.
Harv
Christos
01-04-2006 16:07:39
 Re: massey ferguson 135 in reply to Harv123, 01-04-2006 12:02:48
They typically go for around $5,5k in really good condition. To me personally, since I have and if I had to buy one, I would pay a little more for one if it had the Perkins Gas engine in it as opposed to the Continetal Engine for the sheer reason trying to find a bare block for my tractor was hard (took me about 6 weeks) and it was pricey, at $650.00 but it was the only one I could find. (Generally, Perkins parts are more common and WAY less expensive and better quality in the long run.) Paint is another factor as well as the condition of the sheet - if its been restored, sometimes the paint combination isn't done correctly - red in the wrong parts, wrong shade of grey/silver, etc. MFs are a pain to repaint because they use three different colors to do the sheet and belly. Not everybody notices the shade differences.
For a definate value, if you have an Agricultural Auction near by, call them up and see what one sold or alternatively, check E-bay and the classifieds here. Average them out and you'll get your price.
Hopes this helps,
Christos
DavidP, South Wales
01-03-2006 23:53:06
Hello,
'AG' as far as I am aware refers to 'A' is made by Perkins to MF specification and 'G' is for Gas. If there is a 'U' in it then it was made in the UK. UK tractors changed to the straight front axle from late 1969. That was the main change although there are smaller cosmetic changes.
DavidP
