3-POINT HYDRAULIC PROBLEMS
ROB IN TEX
01-03-2006 09:05:55
I HAVE A MF 255 AND THE 3 POINT HYDRAULIC WHERE LIFTING SLOW SO I CHECK THE OIL AND IT WAS LOW AND THE OIL WAS CONTAMINATED SO I CHANGED THE OIL AND ADDED 32 QT OF AN OIL WITH THE SPEC J-20C,GL-4,TO-2. THE 3-POINT LIFTED A COUPLE TIMES THEM IT STOPPED WORKING.CAN SOMEONE PLEASE HELP!!
THANKS,
ROBERT
kebroad
01-07-2006 07:46:18
 Re: 3-POINT HYDRAULIC PROBLEMS in reply to ROB IN TEX, 01-03-2006 09:05:55
there is a filer on the pump if you look under the back casting you will see a plate held on with 3 bolts remove plate then you will see the filter remove the 1 nut hoding the filter clean it and refit the oit as to be drained or there will be amess .if it does not have the plate you remove the side cover where the pto lever comes from
Jerry/MT
01-06-2006 17:24:19
When you drained the oil did you flush the sump out? If not you might have clogged something. Does your tractor have hydraulic oil filter(s)? Could be it/they are clogged. Is that the right spec oil for you hydraulics?
Sorry I can help more than this. You need to get a shop manual for your machine and then you can trouble shoot it.
Rob in Tex
01-09-2006 08:47:29
 Re: 3-POINT HYDRAULIC PROBLEMS in reply to Jerry/MT, 01-06-2006 17:24:19
Thanks, I checked the hydraulic filter and the filter was clogged.So I cleaned the filter and put it back in and it worked like a champ.
Thanks,
Robert
