massey ferguson 35 loader
Stephen Gissy
01-02-2006 21:24:24
Got a loader for a massey ferguson 35. Got it all put on and hooked the valve up. The loader is hard to get to run. Sometimes it will run fast, sometimes slow, sometimes not at all. I have found out that moving the 3 point arms all the way up helps the loader move. I have also noticed moving the drag levers sometimes helps as well. Does anyone have any suggestions about how to get it to work better or more consistantly?
tg in VA
01-03-2006 11:53:48
 Re: massey ferguson 35 loader in reply to Stephen Gissy , 01-02-2006 21:24:24
Have you tried moving your selector lever to the "Constant Pumping" position?
sgissy
01-03-2006 15:24:03
 Re: massey ferguson 35 loader in reply to tg in VA, 01-03-2006 11:53:48
constant pumping position is with the 3 point hitch lever all the way up right? If it is then that is where i have had it. I was told by someone i needed to chain my three point hitch arms all the way down then raise my lever all the way to constant pumping position?
tg in VA
01-04-2006 07:04:37
 Re: massey ferguson 35 loader in reply to sgissy, 01-03-2006 15:24:03
There are two levers. The outside lever is the draft control. The inside lever is the one you need to have in constant pumping. The constant pumping position is labeled.
Big Dean
01-03-2006 10:39:03
It sounds like you already have a valve on top of the liftcover that will divert the oil either to the three point or to a remote cylinder. There are several different brands and types of those valves and they can be very confusing to use. If you will email me with a description of the valve you have or a picture of it would even be better I can probably tell you what you need to do to make it work.
stephen gissy
01-08-2006 16:59:59
 Re: massey ferguson 35 loader in reply to Big Dean, 01-03-2006 10:39:03
Finally got it figured out. I went and bought a little valve that the local dealer had. It just has a lever. The lever in upright position is in nuetral and the 3 poiint hitch works. When the lever is pushed backwards the front loader works. And when its pushed forward you can run a hyrdraulic disk or piece of equipment in the rear. To work the loader you just use the 3 point hitch lever. Very simple to use and it only cost 60$ brand new.
gerard
01-03-2006 09:07:29
You need a diverter valve to isolate the 3 point whilst you"re working the loader.
Rod in Smiths Falls, ON,
01-03-2006 04:46:09
Stephen:
Higher revs sometimes work to get the oil flowing.
If the loader won't start up when I switch the diverter over, I sometimes have to drop the loader a bit to get the oil flowing.
Getting the diverter valve to the proper position seems a bit tricky. If it positively won't flow, Shut off, switch the diverter, and then start up. It should pump then.
You have tried additional oil in the tranny?
Operating a diverter valve seems to be more art than science. Good luck with it.
Rod
Stephen Gissy
01-03-2006 08:02:51
 Re: massey ferguson 35 loader in reply to Rod in Smiths Falls, ON, , 01-03-2006 04:46:09
I have tried adding more oil in the tranny. I don't believe i have a diverter valve. I have a valve that sits on top of the plate between your legs. Would a diverter valve be a better option?
01-03-2006 17:38:52
 Re: massey ferguson 35 loader in reply to Stephen Gissy, 01-03-2006 08:02:51
That's what I mean by a diverter valve. I may have the wrong name on it.
