MASSEY 44-6
JIM/WIS
01-02-2006 19:48:20
I WILL BE NEEDING TO REPLACE THE CLUTCH ASSEMBLY AND COUPLER CHAIN FOR A MASSEY HARRIS 44-6. WILL I BE ABLE TO REPLACE THESE ITEMS AT A MASSEY/AGCO DEALERSHIP. OR IS THERE A OBSOLETE PARTS CENTER FOR MASSEY OUT THERE THAT I HAVE NOT HEARD OF.
msb
01-03-2006 18:47:17
 Re: MASSEY 44-6 in reply to JIM/WIS, 01-02-2006 19:48:20
Jim, you can get a new clutch disk from NAPA.Its the same as an older Ford truck disk.I can't remember what year truck off hand.Unless some of the links are missing on the coupler chain,I would soak it in penetrant oil for a while and work the rust out if the links by bending it back and forth.
Dave_Id
01-02-2006 20:45:19
It's a good chance you'll need to pick these items up in a tractor boneyard. Place a wanted ad on this site. You should get many responses. The clutch disc can be relined at any clutch and brake shop
JIM/WIS
01-04-2006 19:33:41
 Re: MASSEY 44-6 in reply to Dave_Id, 01-02-2006 20:45:19
I WAS ABLE TO GET THE CLUTCH COMPONENTS AT THE MASSEY DEALERSHIP ALONG WITH A NEW COUPLER. I SHOULD BE PICKING THESE PARTS UP ON FRIDAY, MY NEXT CONCERN WILL BE IF THE SPROKETS ON THE CLUTCH SHAFT, IF THEY WILL NEED TO BE REPLACED, BECAUSE OF THE NEW COUPLER. IAM ALSO GOING TO CHECK THE CLUTCH SHAFT TO SEE IF IT NEEDS TO BE BUILT UP WHERE THE BEARING IS IN PLACE. WHEN I RAN THE TRACTOR, I COULD FEEL VIBRATION AND HEARD A HOWLING TYPE OF NOISE, AT FIRST I THOUGHT IT WAS THE REAR END, BUT PINPOINTED IT TO THE CLUTCH SHAFT AREA.
