twin power
masseypower
01-02-2006 17:37:39
I am new to the massey harris line what does twin power mean thanks for any help
gerard
01-03-2006 15:58:27
 Re: twin power in reply to masseypower, 01-02-2006 17:37:39
What model are we talking about? Do you mean twin power or multipower?
Rod in Smiths Falls, ON,
01-03-2006 04:56:42
On my 1947 30 it is just a throttle setting. There is the usual set of notched adjustments, then a spring-loaded gate and a few more notches. The engine seems to have quite a bit more usable power when I push the throttle "through the gate". I use it only for a short burst of power when nearing the top of our hill in 5th gear, but the boost prevents a downshift on a busy road.
masseypower
01-03-2006 03:00:47
Thank you
dairyman
01-02-2006 17:47:41
it means that for belt work it increases engine speed above the usual max speed that you use for drawbar work if you look at the governer there is a rod that goes moves when the belt pulley is engaged and changes where the stop for max rpm is on the governer.
