Pony Motor
Larry Martin
01-02-2006 11:36:42
Just started assembling a N62 engine for my Pony. I had to get a used block and crank and when I started assembling the motor found that the locating pins for the thrust washer were not in the old block. I can't see why I couldn't drill nwe pins in the bearing cap instead of the block and it would work fine. I don't have the old bearing caps from the used block so I can't tell if the original was this way. This is any early block as it has the bearing cap studs instead of cap screws. Any help will be appreciated.
