Question for STUDIEdiesel63
JaredM
01-02-2006 07:33:21
I was wondering if you could give me any information on a '63 1-1/2 ton Studebaker with a 4-53 Detroit Diesel. Is there a model name for them. Were they available with four wheel. what transmission did they have. My grandpa had one he used to haul around his drilling rig. It has 73 F150 Ranger cab and a NP205 transfer case which makes me think he did the four wheel drive himself. Any info helps. Thanks JaredM
STUDIEdiesel63
01-02-2006 17:50:26
 Re: Question for STUDIEdiesel63 in reply to JaredM, 01-02-2006 07:33:21
OK,first,if its a 1-1/2 ton it would have a serial no.starting with designation E 28 ,then the trucks number.it could certainly have had a detroit,but it would have been the 3-53.
models E-40 and E-45,which were 2ton and 2tonHD,offered the 4-53 engine as an option.
tranny options were,clarke 5-speed,direct or overdrive in 5th,new process 5-speed direct or overdrive in 5th or plain new process 4-speed,could all be had with 2-sp. axle.the 4-wheel drive likely wasn`t factory.
My trucks serial is E-45 906
Hope this helps!
JaredM
01-02-2006 18:20:36
 Re: Question for STUDIEdiesel63 in reply to STUDIEdiesel63, 01-02-2006 17:50:26
Where do I find the serial number and do you know how many were made are they hard to come by? I might try to post a pic its quite a sight. Thanks for responding. JaredM
STUDIEdiesel63
01-03-2006 08:22:32
 Re: Question for STUDIEdiesel63 in reply to JaredM, 01-02-2006 18:20:36
Jared,serial no.is on the studebaker cab,right below the seat on driver side,just above cab step.when you open the door,you should see it,unless it is rusted away.another way is to have or find title to studie truck,serial will be on there.
"supposed total" diesels made is around 500,that includes 1-ton thru 2-tonHD,and 96"BBC. Not totally impossible to find,if you are patient,but big money if you want a good one.
JaredM
01-03-2006 13:19:18
 Re: Question for STUDIEdiesel63 in reply to STUDIEdiesel63, 01-03-2006 08:22:32
Well now we have a problem because the cab is long gone and has been replaced with one from a '73 Ford F150 Ranger but I know grandpa told me it was a '63 Studebaker. Thanks for all the help. JaredM
Rustyj14
01-02-2006 10:27:38
I worked for a Studebaker dealer in 1963, and never heard of a 4 cylinder diesel, available in that year of truck! With it having a Ford cab, etc., i'd want to guess your grandfather made the thing out of parts! I could be wrong about the engine installation, from factory! The dealer had a 1 1/2 ton truck with a factory built tow hoist on it. It was sold when the dealer went out of business! RJ
