MF 65 Tires/rims
Tom Lukas
06-04-2000 12:38:44
I bought the 6 foot mower and it works great! Now my wife doesn't like the cleat marks the tires make on the lawn. I was thinking another set of rims/hubs and turf tires. What do you think? Too much money? TL
Danny
06-05-2000 07:17:48
 Re: MF 65 Tires/rims in reply to Tom Lukas, 06-04-2000 12:38:44
First remove any fluid from the tires and reduce the weight of the tractor on the lawn. the 65 is pretty heavy with fluid in the tires. Then you may be able to run the air pressure a little low and if the ground is not too soft that might work. Do Not Pull any loads with low psi in the tires as that might damage the tires
