MF 285 Solenoid Problems
Tanner H
12-28-2005 18:32:47
I recently put a new solenoid on my 285. The wiring is all correct on the solenoid but the engine wont crank or make a sound when i turn the key. I tried jumping the solenoid and all it does is nothing. The batteries are fully charged. I am drawing 12v at the solenoid when i checked. The solenoid gets really hot after 5 min. of sitting still. If anyone out there can help me, please reply. Thanks, Tanner
Don-Wi
12-28-2005 20:19:16
 Re: MF 285 Solenoid Problems in reply to Tanner H, 12-28-2005 18:32:47
It could just be the starter itself. I would taske it off and have it checked at either an auto store or even better a shop that rebuilds them. back in 87 or so my dad replaced the original ox of a starter with a smaller one that the MF dealer gave him. It's almost 1/2 the size as on my mom's cousin's 285 that still has the original on it.
Donovan from Wisconsin
DavidP, South Wales
12-29-2005 01:37:31
 Re: MF 285 Solenoid Problems in reply to Don-Wi, 12-28-2005 20:19:16
Hello,
Remove the starter and connect jumper leads to the starter. Hold it in a vice or under your foot and 'jump' the solenoid. If nothing happens then it's not an engagement problem. I think you will find that the pinion is tight on the armature (that's the bit that slides to engage in the starter ring. Using a screw driver try and gently prise the pinion rearwards. It should be free and return freely. If you have an inspection band around the end of the starter body, remove it and you'll see the inside, brushes etc. Should be shiny and cleanish. Removal of the end cap is easy but refitting it is fiddly. Better to take it to a repairer.
Cheers
DavidP
