MF 135 three point lift
devildawg(tx)
12-28-2005 03:55:58
I have a 64 135 deluxe with auxillary hydraulics. The problem I"m having is the lift won"t lift heavy implements anymore. One day it was fine, the next day it wouldn"t do it. The auxillary still has full pressure. If you unhook the top link it will snatch anything right up. I"ve changed the relief valve and it does the same thing. Anyone with any guesses as to what may be causing these symptoms. Thanks for any responses.
DavidP,South Wales
12-28-2005 11:41:39
 Re: MF 135 three point lift in reply to devildawg(tx), 12-28-2005 03:55:58
Hi,
Is there a lot of play in the top link rocker linkage? Seems like a problem with either the external or internal linkage and surgery will probably be required. A linkage problem would not affect the auxilliary.
David P
