axle rear inner seal dim.
jimbob2
12-27-2005 06:36:24
I have a Mf 165 in which i am replaceing the brakes, I"m trying to order the inner seals. When I check the dim. on my old seal it checks 3.187-3.200 dependind on where i check it for the o.d.. My axle size is 2.125 at the seal location.
The only size I"ve found on line is 3.375 x 2.350. What"s the deal?
Jim
CHRIS GA.
12-30-2005 20:24:14
 Re: axle rear inner seal dim. in reply to jimbob2, 12-27-2005 06:36:24
HELLO, I AM ALSO REPLACING MY BRAKES ON A MF3165 I"M TOLD THE 165 IS THE SAME TRACTOR. I HAVE THE MF PART # 832954M1 WHICH SUPERCEEDS TO 832954M3. MY SEALS IN THE TRACTOR ARE NATIONAL SEALS. I DONT KNOW WHAT # FOR NATIONAL YET BUT I WILL BE WORKING ON IT AGAIN TOMARROW AND WILL PULL ONE TO MEASURE. I CANT FIND THE MF # ONLINE SO I WILL BE CONTACTING NATIONAL SEALS.WILL POST MORE INFO LATER. THANKS
NEsota
12-27-2005 08:54:02
Last summer I replaced the seals in my 65. Per the Massey dealer receipt, the part # was 261 832954M3 & cost was $12.97 each. Hope this helps you. I do not have measurements
