Massey-Harris
James Acree
12-26-2005 18:25:24
My brother is trying his best to rebuild a Massey-Harris he believes to be a Model 22. Year 1951. This is the number that was stamped into the frame by the clutch pedal. 22 GR 8636. Still waiting to see what he found on the stamp on the engine above the oil filter. Does anyone know what those numbers would bring up?
Alberta Mike
12-27-2005 04:50:50
 Re: Massey-Harris in reply to James Acree, 12-26-2005 18:25:24
Engine numbers are pretty hard to trace and really wouldn't be of much value. For sure it is a 4-cylinder Continental flathead engine, probably a 140 cubic inch version which was used in a large number of agricultural and industrial applications. The 140 has a 3 3/16 bore and a 4 3/8 inch stroke. Most engine parts are interchangeable with the 124 and 162 cubic inch versions of the same engine.
Rod in Smiths Falls, ON,
12-26-2005 20:00:03
Is it a narrow-front row crop model? If so, it might quite well be a 1951, as the serial numbers for the model listed below begin with 7624.
Massey Harris Model 22 RC 1951 7624
For further details see Serial Numbers under Research and Info on the left of this page.
Hope this helps,
Rod
