Chisle Plow or Sub Soiler ?
Lou
12-23-2005 08:18:25
Ive never used either , but its my impression either will work to break up hard pan? How large of one will a MF 175 pull? How much do they cost used? Merry Christmas to all.
gerard
12-27-2005 16:08:45
 Re: Chisle Plow or Sub Soiler ? in reply to Lou, 12-23-2005 08:18:25
We've a ferguson single tooth subsoiler. Goes down about 2 feet with disc removed. Horsepower needed depends on soil. Ours is medium & the MF135 pulls it easily. The TE 20 has to get down to it, but copes in 1st gear. Subsoiling is best done slowly anyway.
DoubleR
12-26-2005 06:27:24
I beleive they figure 45hp per tooth on a sub-soiler. I use a one tooth on a mf231 and its all she wants.
T.J.-A.C.
12-24-2005 08:32:05
I think I saw a 3 point 1 bottom King Kutter sub soiler at TSC it seemed heavy enough for moderate use. The neighbor has an old trip lift IHC on steel that weighs a ton and really does a nice job it must go down 2 feet it came new with the 10-20 and I am sure it was all it could do to pull it. I guess it depends how much production you are expecting to get. T.J.
T.J.-A.C.
12-24-2005 08:31:36
Lou
12-24-2005 06:17:46
Thanks gentlemen , I probably need a subsoiler for small acerage. Now to find one on a limited budget.
95RUSER
12-23-2005 19:38:37
A SUBSOILER GENERALLY GOES DEEPER THAN A CHISEL PLOW, BUT ALSO TAKES MORE HORSEPOWER TO PULL. I'VE GOT A 5 SHANK SUBSOILER AND PULL IT WITH A 1086 IH, AND IT'S ALL IT WANTS. A SMALL CHISEL PLOW WOULD PROBABLY BE YOUR BEST BET. I'VE GOT A 275 MF THAT WILL HANDLE A SMALL CHISEL BUT WOULDN'T DREAM OF HANDLING THE SUBSOILER.
Steve in SJ
12-23-2005 20:00:58
 Re: Chisle Plow or Sub Soiler ? in reply to 95RUSER, 12-23-2005 19:38:37
We used to pull a single shank subsoiler with a JD 2010G about 48 PTO HP and it worked great. Unless you have plenty of horsepower you won"t get a chisel plow deep enough to break up the hardpan completely
