3 pt lift arms MF 175
Lou
12-21-2005 08:45:03
I have the type of arms that benf or lift at the ends to make it easier to attach implements. Handy at times but not always like when your backing up to reset a plow. wonder it these were standard equipment also how long they should be. Maybe nine were changed befor I bought tractor? thanks Lou
Lou
12-23-2005 05:57:21
 Re: 3 pt lift arms MF 175 in reply to Lou, 12-21-2005 08:45:03
Thanks Chuck for that info. My arms definatly do not lock in place. I can see theve been welded Im wondering if theve been shortened a little in the prosess? Tractor is 100 miles from me,Wondering about the cost to replace if necessary? Ill check the arms and repost. Merry Christmas Lou
mn.Chuck
12-22-2005 18:19:41
Those tilting ends should be locked in place and
should be solid except when sliding the pin
along the slot against spring pressure to release so they will tilt. Maybe you are missing
the pin and spring to hold solid. Let me know
if you are and need p/n etc. MF dealer should
have on hand. Chuck.
