2705 transmission problem
Iowa Carl
12-21-2005 04:49:03
My tractor works only in the high speed reverse. I can shift it to forward but the gears barely catch and will not go to the detent position. It is impossible to shift to the lower speed range. The shift column seems to have some vertical play also. Is this a shift column, shift cover, multipower, or shift rail and sliding gear problem? It is towed forward and used only for PTO work for the last year. Any suggestions are welcome!
